281 Fantomas 44,563 Sat 16 Mar - 17:39 (2019)
13 TaMs13 34,891 Wed 20 Jan - 16:37 (2010)
No new posts  [Shineray XY 250 STXE] Problème suite au montage
Cable d’accélération
37 7ony 3,769 Fri 9 Sep - 10:39 (2011)
NoFear View latest post
<b>Moved:</b>  Moved: [XY 250 STXE] reportage photo sur la réception et le montage
9 pom1 646 Mon 5 Sep - 13:15 (2011)
No new posts  300kms en 250STXE et franchement déçu
20 NoFear 2,689 Fri 2 Sep - 21:48 (2011)
pom1 View latest post
No new posts  mecano du dimanche carbu
carbu
14 witzig 1,747 Tue 23 Aug - 08:25 (2011)
No new posts  [Shineray 250 STXE] modifs et améliorations by shinerayby76
[ Goto pageGoto page: 115, 16, 17 ]
196 shinerayby76 20,655 Thu 18 Aug - 22:34 (2011)
shinerayby76 View latest post
No new posts  [STXE 250] acquisition d un stxe by Crafter89
3 Crafter89 755 Sun 14 Aug - 08:28 (2011)
Crafter89 View latest post
No new posts  eclaté du 250 STXE
19 danarou 6,211 Sat 13 Aug - 19:40 (2011)
Marguerite View latest post
No new posts  [STXE 250] Passage cable embrayage
Recherche passage cable embrayage
9 dj cd 753 Sat 13 Aug - 12:28 (2011)
dj cd View latest post
No new posts  [Shineray 250 STXE] Evolution faites sur nos chinois
17 kikili 2,061 Sat 23 Jul - 11:29 (2011)
Poipoi View latest post
No new posts  Changing de A-arms and the oscilant arm.
Needing help to make my quad bigger.
3 miguelcastro83 529 Tue 12 Jul - 20:13 (2011)
fabien View latest post
No new posts  [Shineray 250 STXE] votre Avis sur ce quad
16 mikiemike 1,731 Sun 3 Jul - 21:52 (2011)
No new posts [250 stxe] pbm bras oscillant
du jeu dan le bras oscillant
95 bogoss27 5,814 Tue 28 Jun - 09:21 (2011)
bogoss27 View latest post
No new posts  [ 250 stxe shineray ] Crabot de boite de vitesse hs
13 dollet 2,100 Wed 22 Jun - 18:09 (2011)
dollet View latest post
No new posts  résistance ventilo shineray STXE dans l'eau
shineray dans bourbier
5 quadeur62 1,037 Tue 14 Jun - 20:50 (2011)
polluximos View latest post
No new posts  [Shineray 250 STXE] Références Roulements et chaine
75 danarou 12,060 Fri 27 May - 10:43 (2011)
Logitec View latest post
No new posts  250 STXE Pb jauge d'essence
4 cedriborn 877 Sat 21 May - 08:59 (2011)
No new posts  [250 STXE] Commandé
Tendance Import
3 kikili 640 Fri 13 May - 21:59 (2011)
No new posts [shineray 250 STXE] vibrations
3 ludovenus 1,427 Thu 14 Apr - 10:58 (2011)
No new posts [250stxe] led changement vitesses
fabrication led changement de rapports
3 bogoss27 789 Wed 13 Apr - 15:51 (2011)
Kervi View latest post
No new posts  [shineray 250 STXE] adaptation de jantes arriere plus grandes
27 ludovenus 3,758 Mon 11 Apr - 16:23 (2011)
franks View latest post
No new posts  [shineray 250 STXE] ralenti acceleré à chaud
5 ludovenus 971 Wed 30 Mar - 12:29 (2011)
<b>Moved:</b>  Moved: 1ere sortie avec cam embarqué
14 OLIVIER62 1,182 Tue 22 Mar - 12:38 (2011)
om's View latest post
No new posts  [Shineray STXE] Nouveaux pneus pour mon quad
32 Tarl 3,945 Mon 21 Mar - 21:42 (2011)
OLIVIER62 View latest post
No new posts  changement moteur
7 david08000 800 Mon 21 Mar - 16:29 (2011)
No new posts  [shineray 250 stxe] de l'eau dans la boite à air
16 lolok 3,184 Sat 19 Mar - 22:16 (2011)
No new posts  [STXE 250] question sur la visserie + chtite video
4 Tarl 707 Tue 15 Feb - 16:46 (2011)
No new posts  street quad (shineray stxe)
4 shinerayby76 724 Sat 12 Feb - 18:57 (2011)
calif34 View latest post
No new posts  [stxe 250] Mes modifications
2 christobat30 981 Tue 8 Feb - 22:07 (2011)
No new posts  [250 stxe]comment regler un phare ?
6 bastien1976 1,214 Tue 18 Jan - 21:08 (2011)
Le Tone View latest post
No new posts  recherche personne qui aurait eu 1 problème avec son châssis
10 witzig 1,166 Tue 18 Jan - 09:26 (2011)
Pmimmo View latest post
No new posts  [ Shineray 250 STXE] Mise en place poignée frein HSUN600
Séparation frein avant et arrière
9 Le Tone 2,637 Mon 17 Jan - 17:48 (2011)
No new posts  rotule
5 witzig 937 Mon 10 Jan - 16:06 (2011)
No new posts  [STXE 250 modele 2010] cote bague bras oscillant et triangle 250 stxe 2010
3 Bronson 871 Wed 5 Jan - 14:32 (2011)
No new posts [Résolu] [Shineray STXE] Dépannage et remise en route
shineray stxe "légaliz" recherche de la panne remise en route.
8 perfected 1,407 Mon 3 Jan - 18:26 (2011)
No new posts  [ Shineray 250 STXE ] Poignées chauffantes
Pour braver le froid !
29 Le Tone 2,437 Wed 22 Dec - 18:20 (2010)
Airman View latest post
No new posts  modifs de mon stxe
8 julien250cc 1,218 Sat 16 Oct - 13:20 (2010)
No new posts  [shineray 250 stxe ]
clignotant goutte d'eau
13 Stéphane27380 2,956 Sun 3 Oct - 18:07 (2010)
Stéphane27380 View latest post
No new posts  [Résolu] probléme lors de l'acceleration
[shineray xy 250 stxe]
11 shinerayby76 1,097 Sat 2 Oct - 10:35 (2010)
Pierre02 View latest post
No new posts  [Shineray 250 stxe] Comment puis je le débrider ?
[ Goto pageGoto page: 18, 9, 10 ]
110 tristan 50,879 Wed 29 Sep - 12:20 (2010)
No new posts  mettre un filtre a air racing dans la boite a air
14 benoit31 4,445 Sun 26 Sep - 09:06 (2010)
Luca View latest post
No new posts  [250 STXE] - Les améliorations réalisées
Pot, carbu, allumage, boite à air, freinage...
[ Goto pageGoto page: 110, 11, 12 ]
132 Stefen76 14,661 Mon 20 Sep - 20:54 (2010)
No new posts [Shineray 250STXE] mon [250 stxe] au fil du temps by mcniglo
sujet les l'entretien et modif
12 mcniglo 1,544 Thu 16 Sep - 18:23 (2010)
No new posts Réglage carburateur
11 Stéphane27380 1,440 Mon 13 Sep - 17:22 (2010)
mike86 stxe View latest post
No new posts Reglage du parallelisme, Purge des freins pour nul
11 Legaliz 7,432 Tue 10 Aug - 21:06 (2010)
momo View latest post
No new posts  [250 stxe] commande chez bm auto
45 Malbrancq 5,223 Fri 6 Aug - 00:08 (2010)
No new posts  réglage soupapes et serrage culasse
5 lolok 3,798 Wed 4 Aug - 08:24 (2010)
No new posts  [shineray 250 stxe] Quelques soucis ...
12 Enigma 3,869 Wed 4 Aug - 06:14 (2010)
No new posts  [250 stxe] changement filtre à air !
5 lud17 2,981 Sun 1 Aug - 17:17 (2010)
cardin View latest post
No new posts  référence cable embrayage adaptable
1 dj cd 717 Sat 10 Jul - 13:33 (2010)
danarou View latest post
No new posts  [Shineray 250STXE] Feedback vraie premiere sortie
7 Tarl 1,958 Wed 7 Jul - 16:47 (2010)
Tarl View latest post
Post new topic    CHINESE QUAD Forum Index -> Les Types de QUAD -> SHINERAY -> XY 250 STXE
Goto page: <  1, 2, 3, 4, 5, 6  >
Page 3 of 6
