281 Fantomas 23,819 Sat 16 Mar - 17:39 (2019)
13 TaMs13 17,479 Wed 20 Jan - 16:37 (2010)
No new posts  [shenke 250 st25d] probleme ventilateur
22 SIMON 2,421 Sun 13 Nov - 18:58 (2011)
axel View latest post
No new posts  [dinli 270] sonde de temperature
2 rom1cha 1,625 Mon 10 Oct - 07:31 (2011)
Poipoi View latest post
No new posts  [ dorton 200cm3] probleme branchement ventillo en direct
1 sylvain11610 664 Sat 8 Oct - 11:12 (2011)
No new posts  [HYTRACK 420 - 4X2] fuite liquide de refroidissemet
20 fabien 3,477 Fri 7 Oct - 13:16 (2011)
No new posts  [shineray 250 stixe] surchauffe
Monte en teméprature
11 romain77 1,488 Wed 28 Sep - 03:07 (2011)
No new posts  [jinling jla 21b 250c] Refroidissement liquide ?
[JLA-21B]
8 aurelien 1,146 Wed 17 Aug - 10:33 (2011)
Jeff06 View latest post
No new posts  [Résolu] [kymco 300 MXU] comment nettoyer les ailettes radiateur????
nettoyer un radiateur sans le demonter?????
63 jerome02 5,420 Fri 12 Aug - 17:50 (2011)
NoFear View latest post
No new posts  [Résolu] [stixe]renseignement durite LR
9 manyboss 859 Tue 2 Aug - 16:21 (2011)
No new posts  [Shineray 250 Stixe]Surchauffe
Quad qui monte vite a 100°
28 kevin02100 4,094 Tue 5 Jul - 21:43 (2011)
kevin02100 View latest post
No new posts chauffe de mon mteur
shineray stxe 250
5 jp34300 1,106 Fri 1 Jul - 23:51 (2011)
This topic is locked: you cannot edit posts or make replies.  ajout d un ventilateur pour radiateur a huile
7 vwtm2006 915 Tue 28 Jun - 15:22 (2011)
No new posts  [Shineray 250 STXE] probleme ventilateur
3 Lavandst 2,734 Sun 22 May - 13:51 (2011)
Lavandst View latest post
No new posts  [250 predator] Mon ventilateur tourne en permanence
10 rjm 1,424 Thu 5 May - 09:08 (2011)
babytos51 View latest post
No new posts  moteur qui chauffe sur route
88 boris 13,802 Thu 28 Apr - 12:21 (2011)
Firesdn59 View latest post
No new posts  [250 STIXE] fuite liquide de refroidissement
26 moprale 4,029 Sat 26 Mar - 09:53 (2011)
kevindu28 View latest post
No new posts  Fuite radiateur STIXE ou ST9-E
9 moussdu29 1,451 Sat 26 Mar - 09:40 (2011)
No new posts  [mikilon 250] ou trouver des turbines de ventilateur ?
3 lusitano91 565 Mon 7 Mar - 13:38 (2011)
No new posts probleme chauffe et tremblement quad
34 chamois05 7,602 Sun 30 Jan - 18:06 (2011)
cardin View latest post
No new posts  Quel filtre à air pour un roxon 50 ??
11 Damien Go 1,269 Mon 10 Jan - 19:04 (2011)
Damien Go View latest post
No new posts  [mikilon 250] pompe a eau
2 johann 597 Wed 17 Nov - 09:43 (2010)
No new posts  [Résolu] [sy250stxe] ventilateur casser
46 babytos51 2,861 Thu 14 Oct - 17:13 (2010)
No new posts  [Shineray 250 ST-9E]Faire la mise a niveau du liquide de refroissisment
7 yobbboss 1,170 Wed 11 Aug - 15:49 (2010)
No new posts  [Road Trip 250] Probleme liquide de refroidisement
16 christopher 1,788 Fri 30 Jul - 10:36 (2010)
christopher View latest post
No new posts  Radiateur qui fuit!!!
43 Berty 4,305 Sun 11 Jul - 11:33 (2010)
Edywal View latest post
No new posts  Ou acheter un Sonde de température pour 250 stxe
1 willmax 937 Mon 28 Jun - 08:43 (2010)
No new posts [Shineray ST-9E] Fuite radiateur
grrrrrrrrrrr c cassé
2 nikolalala 657 Wed 9 Jun - 16:12 (2010)
No new posts [Résolu] [Bashan200] Radiateur cassé
19 gregory8211 1,530 Tue 27 Apr - 11:23 (2010)
No new posts  par quel model remplacer un radiateur de stixe?
6 collin-vincent 833 Sat 6 Mar - 08:18 (2010)
Berty View latest post
No new posts  Changer son LR sur STIXE ???????????
7 moussdu29 795 Tue 16 Feb - 15:45 (2010)
No new posts  pompe a eau
10 yobbboss 990 Tue 2 Feb - 21:27 (2010)
Pat59 View latest post
No new posts  ou se trouve la sonde
8 yobbboss 967 Mon 11 Jan - 10:31 (2010)
No new posts  [Résolu] [XGJ250ST]problème de ventilateur
ventilateur en panne
10 om's 867 Thu 7 Jan - 16:48 (2010)
No new posts  [stixe 250] Ventilateur qui ne déclenche pas !!!
20 yobbboss 4,600 Mon 4 Jan - 17:18 (2010)
No new posts  demontage pompe a eau st9e
8 cortex 2,758 Tue 22 Dec - 17:03 (2009)
No new posts  ventilateur qui tourne en permanance
ventilo
5 lud17 908 Tue 8 Dec - 11:47 (2009)
miacali View latest post
41 morgan12 2,583 Mon 30 Nov - 16:29 (2009)
No new posts  sa chauffe de suite
7 riri 776 Wed 18 Nov - 15:27 (2009)
No new posts  vidanger le liquide de refroidissement d'un 250 stixe
2 collin-vincent 1,115 Wed 18 Nov - 15:25 (2009)
No new posts  Ventilateur
Quel organe declenche le ventilateur ?
4 frederic6262 939 Tue 17 Nov - 20:58 (2009)
frederic6262 View latest post
No new posts  temperature de mon quad
44 eric67 3,372 Mon 9 Nov - 21:17 (2009)
No new posts  Probleme radiateur
16 gugu55 2,511 Sun 8 Nov - 01:02 (2009)
No new posts  echangeur additionel
7 franc-x-marc 691 Fri 23 Oct - 12:12 (2009)
Thebrave View latest post
No new posts  Fuite liquide refroidissement
19 K-4sh™ 2,351 Mon 19 Oct - 10:22 (2009)
No new posts  Ventilateur ne declenche pas sur 250 STXE
4 cameleon 1,010 Fri 16 Oct - 18:37 (2009)
danarou View latest post
No new posts [700 HSUN] Tuyau sortie de pompe à eau
Orifice sous la pompe à eau non raccordé
30 CHERPI88 4,661 Sun 11 Oct - 20:14 (2009)
No new posts  double ventilateur
double ventilateur
19 zril 34 1,470 Tue 6 Oct - 06:35 (2009)
zril 34 View latest post
No new posts  comment faire les niveau du refroidissement
21 tetrakox 2,106 Fri 2 Oct - 07:44 (2009)
No new posts  refroidissement
sonde Shineray 250 STIXE
24 Edywal 1,728 Sat 26 Sep - 13:20 (2009)
yoyo76 View latest post
No new posts  Ventilateur stixe ne se declanche pas
Ca chauffe la dedans!!!
13 jhon78 3,226 Wed 2 Sep - 14:00 (2009)
9 morgan12 1,148 Wed 2 Sep - 13:58 (2009)
Post new topic    CHINESE QUAD Forum Index -> L'ATELIER CHINESE -> Moteur -> Refroidissement
Goto page: <  1, 2, 3  >
Page 2 of 3
