281 Fantomas 20,864 Sat 16 Mar - 17:39 (2019)
13 TaMs13 14,821 Wed 20 Jan - 16:37 (2010)
No new posts  dirt 90cc semi auto !!
problème !
10 mini72cc 303 Thu 27 Dec - 19:14 (2018)
mini72cc View latest post
No new posts Poussoir hydraulique tendeur de distribution [ dirt 125]
Remontage
2 AK_r_iZi 317 Fri 29 Jun - 10:50 (2018)
AK_r_iZi View latest post
No new posts  dirt kxd 706
help me
18 riri02 481 Fri 11 May - 09:37 (2018)
cjodi309 View latest post
No new posts  réglage soupapes sur [ 200 Zhongshen ]
9 regisdu10 1,308 Sun 24 Dec - 16:45 (2017)
gage View latest post
No new posts  Problème [ dirt 250cc agb38 ]
8 Sier 1,381 Sat 3 Dec - 20:08 (2016)
Sier View latest post
No new posts  [ apollo 125 AMD-5 ] sortie de grange
16 gage 8,292 Sat 23 Apr - 18:17 (2016)
poussin56 View latest post
No new posts  [orion 4 modifié] pitbike sauvée de la presse!!
12 sebos 1976 1,782 Fri 26 Feb - 23:24 (2016)
No new posts  [ dirt 250 ] gros probleme electrique!!!!
2 tonio22150 629 Fri 1 Jan - 23:40 (2016)
Nours View latest post
No new posts  [agb 38 250] petit saut de chaine apres changement pignon
15 liomatt 1,397 Sun 13 Sep - 16:09 (2015)
liomatt View latest post
No new posts  [ Dirt lifan 125 ] Problème monte trop dans les tours
29 xFusi0n 5,793 Fri 31 Jul - 17:24 (2015)
No new posts  dirt 125 loncin
casse répété cable
0 gt addict 539 Fri 26 Jun - 06:23 (2015)
gt addict View latest post
No new posts  montage crd x2 sur [ 250cc orion agb38 ]
45 liomatt 2,370 Fri 19 Jun - 06:26 (2015)
No new posts  Jeu au soupape moteur 250 zongshen
63 liomatt 7,323 Fri 22 May - 16:50 (2015)
No new posts  [dirt 250cc moteur loncin] jeu culbuteur
2 max73 931 Sat 3 Jan - 17:48 (2015)
max73 View latest post
No new posts  pression pneus [ dirt 250 ]
0 liomatt 545 Sat 1 Nov - 09:27 (2014)
No new posts  (dirt 140) Problème fuite moteur
1 xFusi0n 656 Fri 29 Aug - 09:31 (2014)
No new posts  [250agb38 orion] renseignement carbu avec CDI racing
9 liomatt 1,411 Sun 25 May - 15:20 (2014)
No new posts  [ agb 38 ] changé jante 21/18 par 17/14
9 liomatt 817 Thu 22 May - 16:54 (2014)
No new posts  (dirt 125) Embrayage très mou
10 xFusi0n 1,457 Mon 12 May - 21:50 (2014)
xFusi0n View latest post
No new posts  [dirt 125 gonguy] Problème démarrage dirt bike.
5 xFusi0n 1,177 Tue 25 Feb - 17:37 (2014)
No new posts  [dirt xb-33b 250cc]
Grosse Revision De La Dirt
48 christopher 3,827 Sat 4 Jan - 18:37 (2014)
christopher View latest post
No new posts  Mon ancienne dirt
[ gunshot 140cc YX ]
2 réunion974 1,339 Mon 9 Dec - 15:09 (2013)
Marguerite View latest post
No new posts  (résolu) [ 125 apollo ] impossible à faire partir
[ Goto pageGoto page: 18, 9, 10 ]
117 gage 5,279 Mon 2 Dec - 21:59 (2013)
routch View latest post
No new posts  [Dirt CRZ 125] Mon nouveau joujou
5 xFusi0n 804 Fri 8 Nov - 00:38 (2013)
No new posts  [125 Speedmini]
3 adac3 717 Wed 29 May - 11:53 (2013)
No new posts  Achat dirt bike [small-mx1 125cc]
conseils pour achat !
11 Théo893 1,014 Sat 18 May - 00:12 (2013)
Damien Go View latest post
No new posts  présentation d'une des dirt de mon fils !!!
2 bouba34 678 Wed 10 Apr - 21:54 (2013)
bouba34 View latest post
No new posts  [Dirt bike 250 cc apollo orion agb 38]
6 yoyo89 3,245 Tue 29 Jan - 08:38 (2013)
No new posts  [Résolu] [rx 145]
problème soupape
5 chris77 1,329 Thu 15 Nov - 22:54 (2012)
chris77 View latest post
No new posts  [AGB 36] une tite rx 250
2 charly91 1,992 Wed 12 Sep - 17:42 (2012)
No new posts [125 CRZ]
clavette qui se cisaille
12 benji-02400 1,182 Sat 18 Aug - 10:02 (2012)
No new posts [Résolu] [ 125 CRZ ]
distribution décalé
5 benji-02400 699 Mon 6 Aug - 15:13 (2012)
No new posts  [dirt xss 125]
problème moteur
6 bouba34 954 Thu 26 Jul - 23:25 (2012)
radiateur percee
2 christopher 667 Tue 17 Jul - 17:28 (2012)
No new posts  Ma dirt by Greg22500
12 Greg22500 1,264 Mon 16 Jul - 22:21 (2012)
Greg22500 View latest post
No new posts [dirt RSR 125] fuite d'huile.....carter fissurer
18 bouba34 4,182 Wed 27 Jun - 21:11 (2012)
No new posts  [xb-33] aligner roue arriere
2 christopher 583 Mon 25 Jun - 15:49 (2012)
No new posts  fuite huile moteur
2 k-rabiner98 545 Sat 5 May - 19:47 (2012)
k-rabiner98 View latest post
No new posts  [125 crz] Réglage jeux aux soupapes
2 zigzag49 5,388 Wed 4 Apr - 21:18 (2012)
zigzag49 View latest post
No new posts  [ 125 Crz ]
accoup dans la chaine
8 benji-02400 1,522 Thu 22 Mar - 10:49 (2012)
No new posts  achat dirt bike
2 christopher 594 Mon 12 Mar - 11:24 (2012)
quadeur62 View latest post
No new posts Résurection et restauration dirt bike AGB 30 200 cc
32 réré 4,499 Sat 21 Jan - 13:55 (2012)
rom1cha View latest post
25 christopher 2,117 Mon 14 Nov - 20:46 (2011)
No new posts  Recherche Kit frien Arriere dirt bike 250 cc
7 Maxens06 726 Sun 30 Oct - 13:14 (2011)
No new posts  [pitbike 200 ou 250]
help
52 predator76000 3,328 Wed 31 Aug - 08:01 (2011)
No new posts  Projet dirt 125 construction de A à Z
Base : cadre YCF - moteur Zongshen
9 Damien Go 1,589 Fri 12 Aug - 08:58 (2011)
canibus View latest post
No new posts  dirt bike 125 [AGB-37 orion]
dirt qui desfois a beaucoup de compression et quelque fois en n'a quasiment pas
8 kaiser 2,803 Sun 17 Jul - 09:36 (2011)
philjack View latest post
No new posts  [ 125 Crz ] Reglage culbuteur
reglage culbuteur
7 benji-02400 1,155 Sat 16 Jul - 20:42 (2011)
benji-02400 View latest post
No new posts Dirt bike 125cc deraille
Ma dirt deraille
6 kevin02100 2,971 Tue 5 Jul - 21:41 (2011)
kevin02100 View latest post
No new posts  [AMD8 250cc APOLLO qui pise l'essence]
2 papoun 776 Wed 25 May - 20:32 (2011)
Post new topic    CHINESE QUAD Forum Index -> NOS COUSINS LES 2 ROUES... -> Les dirts bikes
